Home Forums Products Eurorack Modules Misha Sequencer options Reply To: Misha Sequencer options
#167752
capsella
    New Misha user here 🙂
    If I hold + and add a note with an interval button, say 0, while the tone row is playing, it adds it after each note rather than at the end of the sequence as the manual suggests. Is there a setting I need to change to have it only add a single instance at the end? Or am I mis understanding the manual?
    Adding to the Interval Button Sequence
    If user 4 (+) is pressed and held, then pressing an interval button will cause that interval to be appended to the end of the interval button sequence. One can even add multiple instances of such sequence intervals.
