Home › Forums › Products › Stompboxes › H9 loses presets on power off › Reply To: H9 loses presets on power off
January 2, 2023 at 5:56 pm
#168132
Hi Alan,
Are you executing the MIDI channel programming on the H9 itself or the H9 Control software? Any time it’s set directly on the pedal, the setting is stored forever; no save process is necessary. If you are using H9 Control, however, sometimes you need to double check that the setting is in place before moving on. I usually make the change, exit the menu and then re-enter to make sure the change stuck. It’s not uncommon for the app to take a second or two longer for the change to stick, but once again, no save process is necessary.
