Home Forums Products Stompboxes H90 with Boss ES-8 Reply To: H90 with Boss ES-8
#168608
rograt
    I have just received my H90. I am already thrilled with it and have enabled Dual Routing for use with my trusty Boss ES-8.
    I have ES-8 Loop 7 pre Volume loop using In/Out 1 of the H90
    I have ES-8 Loop 8 post Volume loop using In/Out 3 of the H90
    Initial problem is that none of the factory presets are set up this way so all effects are coming out through Loop 7 (before gain stages of the amp and the last thing I want as the default).
    The Quick Reference Guide states “H90 has a complete set of alternate Program Lists with Dual Routing”.
    Does anyone know how I access this alternate list so I can quickly familiarise myself with the sounds?
