Home › Forums › Products › Stompboxes › H90 Outputs 3/4 Sum to Mono (Dual Mode) › Reply To: H90 Outputs 3/4 Sum to Mono (Dual Mode)
February 2, 2023 at 8:43 am
#168823
Hello WrendorWC, Yes, this is true. When running in Dual Mode, and you want a mono signal, you should use output three. The Algorithms automatically adjust for mono operation.
Thank you for the quick response!
