Home Forums Products Stompboxes H90 usb noise Reply To: H90 usb noise
#169022
    It sounds like there is a USB ground loop happening in your setup.
    You can try plugging the H90 or computer into a different outlet or powering both devices from the same outlet and this may resolve the issue. You could also try a USB isolator.
    I cannot provide a timeline for an H90 Control iOS app, so I would suggest doing some troubleshooting to fix your USB ground loop.
