Home › Forums › Products › Stompboxes › H90 – Midi transmit tap tempo but not program change? › Reply To: H90 – Midi transmit tap tempo but not program change?
#169053
    I don’t know if this will work in your setup, but this struck me as the simplest possible solution:
    MIDI Clock is not channel-specific, so it will work across all channels on your receiving devices.  Can you set your downstream  pedals, etc. to another MIDI Channel?  Any one, other than the H90’s Transmit Channel?
    I keep a MIDI Solutions Event Processor Plus under the pedalboard for problems like this.  Invaluable to me, but I understand that not everyone would want the added expense & programming time.
