Home › Forums › Products › Stompboxes › Tap Tempo switch for “Fast/Slow” rotary speed control? › Reply To: Tap Tempo switch for “Fast/Slow” rotary speed control?
#169103
    Yes, these are called Performance Parameters and are available to assign to the footswitches in Perform Mode. If your Rotary Preset is loaded on Preset A, press the Perform button to enter Perform mode, and press the A LED to cycle through the Performance Parameters until you find the Speed parameter.
    https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/play-modes/perform.html#performance-parameters
