Home Forums Products Eurorack Modules Problem with clock sync on Misha Reply To: Problem with clock sync on Misha
#169180
    Can you be more specific when you say “the tempo won’t change”? If you press the shift button a few times to get to the tempo menu, does the BPM of Misha sync to the BPM you are sending it from the other device? What happens when you go above 150 BPM?
    On Misha, what are your Clock Div settings? The best way to troubleshoot this would be setting your Clock Div on Misha to 1/4. I am not having any issues with having Misha sync to a 240 BPM when both devices are set to 24 PPQ.
