Reply To: H90 Routing Display Suggestion
Home Forums Products Stompboxes H90 Routing Display Suggestion Reply To: H90 Routing Display Suggestion
#169484
joecozzi
You are correct, you’re not missing anything. Thank you for sharing your thoughts on this, though we’re more concerned about taking up too much space on the display with too many icons for routing when it can easily be discovered in the Routing menu. Your suggestion is noted, nonetheless.
