Home Forums Products Stompboxes Dive Bomb with Expression Pedal settings for H9 or H90 Reply To: Dive Bomb with Expression Pedal settings for H9 or H90
#169542
    Serendipity.  I was just fine-tuning a Program along these lines earlier this week.
    I have the (glitchier) Whammy IV here for comparison.  I’d need to dig out the Ricochet for A/B.  With guitar amps (but not FRFR), I lose the Dive Bomb near the bottom of that -3rd octave anyway.
    I prefer the Polyphony algo for a hard Whammy slam.  Better chord resolution; less of a ‘blanket’ over it, than the PitchFlex at 100 Mix.  But I do miss the Flex switching there, and its Shapes.
    I tried out several different approaches:
    • PitchFlex tap-dancing (switch for MIX 0-100; pedal for Whammy; switch back MIX 100-0):  Not very smooth.
    • EXP to both PitchFlex voices OFF to -2 OCT, and the Manual parameter:  The On / Off transitions at mid-throw are easily heard, especially with slower ‘bends’.
    • Convoluted multiple MIDI CC messaging to both MIX & Pitch: Not transferable to most rigs.
    • PitchFlex into Polyphony in series:  Work in progress.  Mixed results.
    I will say that I get smoother Pitch change resolution with a MIDI expression pedal, as opposed to RV-5s.  Either way, if you go slow enough, you’re going to hear some discrete intervals.
    With Polyphony, in mono or stereo, I use both voices sync’ed together, Uni to -2 OCT,  Manual target for EXP.   Gain-stage that doubled boost downstream.  MIX 100%, not many frills beyond that.
    But I do Pan both voices, and add a tiny bit of Detune (+/- 1 cent or so).  Seems to help out with the separation & clarity when transitioning from Bypass to Active.
