Reply To: Midi PCs on the H-90 different user-banks?
Home Forums Products Stompboxes Midi PCs on the H-90 different user-banks? Reply To: Midi PCs on the H-90 different user-banks?
#169640
The H90 will only load Programs from the currently select list, this is called the Playlist. You must first select a new Playlist before you can load Programs from that list. You cannot select a different list using MIDI, you must do that from the system settings or using H90 Control.
