Home Forums Products Stompboxes H9 Pitch Shifting with Fender Strat Reply To: H9 Pitch Shifting with Fender Strat
#169682
    You can try the Vibrato algorithm and see if you like how that sounds. The default preset “Swamp Moon” has the expression pedal mapped to the intensity, so at the heel position there will be no effect, and you will hear more of the the effect as you adjust the pedal towards the toe.
