Home Forums Products Stompboxes H9 MONO summing? Reply To: H9 MONO summing?
#169812
Heathcliff
    Thank you for getting back.
    I’m going stereo into the first H9 from another chorus pedal (i love choruses and delays).
    The pitch mix Is set differently depending on what I Need from the preset. If i go out mono from the second H9, i loose the left or the right side of the algorithm of the first one, which Is always connected stereo in the pedalboard
    A few quick questions: Are you going mono in (lnput 1 only) in the 1st H9, or stereo in (Input 1 & 2)? Do you have the Pitch Mix control centered, or off to the left or right? [It is usually called that, but may vary, depending on the loaded algorithm. Often the second parameter, right after MIX]. Can you give me an example situation that I can test? Such as 1st H9 uses Vintage Delay, the 2nd H9 is Flanger (or however you have it set up when you’re getting those results).
