Home Forums Products Stompboxes H90 AND TABLETTE SAMSUNG S8+ Reply To: H90 AND TABLETTE SAMSUNG S8+
#169905
    If you’d like control of each transport command, you’ll need to use an aux switch or MIDI controller. If you’d like to control everything from the H90, you can use the 1-button looper. All the information about the looper can be found here: https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/algorithms/looper.html
    Try loading the Looper into Preset A. Then press the Perform button, and press the A LED button until you see the 1-button looper functions. Read the instructions in the user manual above for details about the 1-button looper.  Use the max length parameter to determine how long the loop is.
    Let me know if that clears things up for you.
