Home Forums Products Stompboxes H90 algorithms doesen’t detect stereo signal from stereo loop Reply To: H90 algorithms doesen’t detect stereo signal from stereo loop
#170541
wedelich
    We’ll need more information (pictures help) regarding your setup. What’s your cable / signal routing? E.g. Mono in / stereo out of H90 with stereo insert?
    A picture of the HX Stomp routing screen, and a picture of the H90 Routing screen would help too. Plus double check your connections in all the units. Make sure you’re using In 3 / Out 3 for the left insert signal, and In 4 / Out 4 for right insert signal.
    By “bypass the algorithm’s” are you referring to the H90 or HX Stomp?
