Home › Forums › Products › Plug-Ins › Split Eq Side processing › Reply To: Split Eq Side processing
April 20, 2023 at 11:31 am
#170557
You are correct that the Mid/Side controls in the plugin are for imaging purposes only. There’s no way to only process the side channel.
However, with a bit of routing in your DAW, you should be able to set up a track to only process the side channel, and feed that to SplitEQ.
