Home Forums Products Stompboxes Switching Between Guitar and Bass H90 Reply To: Switching Between Guitar and Bass H90
#170746
joecozzi
    do you have any recommendations how how to deal with the source instrument? It seems the source instrument settings is global only and cannot be changed between presets, or even with MIDI. Would you perhaps just manually change it when using the H90 with bass?
    Correct
    Or would you just leave it set to guitar and just try and tailor some presets to work on bass regardless?
    This will also work. The biggest changes that happens when selecting “bass” or “guitar” are adjusting the tone controls so they work in a meaningful part of the spectrum for bass. Also, the pitch tracking is optimized for bass. If you’re not going to be leaning heavily on those types of sounds, setting it to Guitar will be totally fine.
