Home Forums Products Stompboxes Glitching on harmoniser H9 Max Reply To: Glitching on harmoniser H9 Max
#170897
joecozzi
    Hello Bunter,
    Can you describe your signal flow? Where in the signal chain are you using the H9 when you’re using a pitch shifting algorithm?
    What are you trying to accomplish when you use a pitch shifting algorithm?
    Similarly, which pitch shifting algorithm are you using to do that? Often times, it’s important to select the right effect for your desired result.
