Home Forums Products Stompboxes H90 Feature Request: Global Kill Dry MIDI CC# Reply To: H90 Feature Request: Global Kill Dry MIDI CC#
#170934
Lodeman
    Thanks for replaying!
    It works as a MIDI CC. Thanks for that!
    But it doesn’t work as intended if I assign an aux switch as  a global control.
    When Global, the aux switch behaves as a momentary switch. Not as a latching.
    For example, if I assign a aux switch to P in Gain, when I press goes to 12db and when I release goes to -60.
    This is a problem, because when I assign the aux switch inside a  specifc Program, it works as intended (like a latching), but when assigned to GLOBAL or MIDI TRANSMIT it works as a MONETARY switch. Maybe there is a problem here…Should work as a Latching for both.
    Thanks again!
