Home Forums Products Stompboxes H90 Feature Request: Global Kill Dry MIDI CC# Reply To: H90 Feature Request: Global Kill Dry MIDI CC#
#170943
    You’re welcome.
    What aux switch are you using? I just tested this and my aux switch has latching behavior. Note that you’ll need to use a momentary normally open aux switch for it to function properly with the H90.
    Also, make sure that you’ve set the input to use an aux switch and calibrated it before testing. This is configured in System Settings > I/O.
