Home Forums Products Stompboxes H90 not updating to 1.5.2 Reply To: H90 not updating to 1.5.2
#171175
joecozzi
    Hi David,
    1.3.7 sounds like the H90 Control version, not the H90 software version. Get into the pedal’s System menu > About. That should tell you what firmware number the pedal is on. Next, try this. In the pedal’s Presets edit menu, set the Effect filter type to Pitch with the middle Quick Knob. Then, with the third Quick Knob see if you can set the Algorithm filter type to PolyFlex. Does it show up now?
