Home › Forums › Products › Stompboxes › H90 Triad Voicing Harmony › Reply To: H90 Triad Voicing Harmony
May 23, 2023 at 4:27 pm
#171462
Pretty sure that is how diatonic works – otherwise the scale would not be relevant and you would use a different algo that uses relative pitch and not harmonic pitch as outlined in the algo notes below. I will have to test you assertion Udi. Perhaps it behaves as you say. Root should have M3 interval, 2nd should have m3 interval, 3rd should have m3 and so on (if a major scale is selected).
