Home Forums Products Stompboxes H90 Diatonic – Learn from Aux Switch? Reply To: H90 Diatonic – Learn from Aux Switch?
#171605
    As an example, assume Diatonic is in Preset A.  Click on the Perform knob.  Use the middle LED button to cycle through the parameters until you reach LEARN.
    Press & hold that same middle LED button to assign LEARN to an external controller.  In this sub-menu, you can even Learn (Ctl Source) the LEARN (Parameter).
