Home › Forums › Products › Stompboxes › H90 Diatonic – Learn from Aux Switch? › Reply To: H90 Diatonic – Learn from Aux Switch?
May 31, 2023 at 2:52 am
#171646
Thanks @brock for the advice. Right now I use FS2 for Active/Bypass and FS5 for Learn, but I’d like to assign Learn to Aux Switch 1 for less toe tapping.
If I follow your instructions it seems like the assignments are made to the builtin foot switches but can be also triggered externally. If I also assign FS5 to be triggered by Aux Switch 1 then it does trigger Learn but also triggers Active/Bypass as well as tap tempo! That seems odd. What would be nice would be to assign Learn to an external controller without a dependency on the built in foot switches.
