Home › Forums › Products › Stompboxes › H90, 2x looper › Reply To: H90, 2x looper
June 1, 2023 at 2:06 pm
#171682
“Whenever we’re editing Performance Parameter Mappings, there most certainly is a distinction between A and B. Next time you enter that mode, the first icon on the top left indicates whether you are in A or B. By simply pressing the LED Button for A or B, you can switch to the correct slot you want to program….”
Thanks @joecozzi. That was exactly the prompt I needed. Once I figured out why I wasn’t seeing what you described, I was quickly able to dial in MIDI assignments, and everything on both loopers now works as expected. Y’all are the best.
Cheers!!
