Home Forums Products Stompboxes Sound Difference Series vs Parallel with only 1 preset being used Reply To: Sound Difference Series vs Parallel with only 1 preset being used
#171834
joecozzi
    Can you give us some more insight into your setup? I know you’re using Dual mode, but are both presets on the same path or is there a preset per path? What Bypass Mode are you using? Are both sets of outputs,1&2 and 3&4, hooked up to the same type of input? Are you running all I/O at the same operating level?
