Home Forums Products Stompboxes H90 Software Latest Reply To: H90 Software Latest
#171971
    H90 Release 1.5.6
    This release contains minor bug fixes and improvements.
    TriceraChorus Preset Fixes
    • For users of TriceraChorus prior to 1.5, this release fixes the behavior of the Env controls which are now separated out as Env Mix and Env Rate
    • To maintain the sound of presets from prior versions (where the Env knob was non-functional), both these knobs will default to OFF when presets are upgraded from the previous 1.3 software
    • If you had TriceraChorus presets imported from H9, they can be re-imported using H90 Control 1.4+ and the single Env control will map correctly onto the new Env controls
    Other Bug Fixes
    • fix Insert Polarity switch on the right channel of a stereo insert
