Home › Forums › Products › Vsig and Preset Development › H9000+Vsig3 bugs › Reply To: H9000+Vsig3 bugs
June 25, 2023 at 3:06 am
#172139
I’ve got a new one, apparently introduced in H9000 FW 2.1.10 / Emote 2.1.2.
TapKnob is no longer displaying values on device or in Emote. Only the name of the control is visible. Documentation states that the ‘s’ format should be used for values but what has actually previously worked is the ‘f’ format, so that is what all my algos use.
So for example to display cutoff in Hz on a tapknob you would previously use “Cutoff:%4.1fHz” but that no longer works, however neither does “Cutoff:%4.1sHz”
I’ve tried different permutations and adding/removing characters and spaces but try as I might I cannot get values to show up anymore.
