Home › Forums › Products › Vsig and Preset Development › H9000+Vsig3 bugs › Reply To: H9000+Vsig3 bugs
Here’s a few I’ve stumbled across.
uo_switch doesn’t work for non-menupage objects. Only works for menupages. I’m not sure if the whole connected to HEAD is still relevant in the H9000 as per the manual page.
curve – I don’t get expected values out of it when trying to build a waveshaper or map. It seems to add an extra point somehow, or the input is not mapped over the full range. I need to pin down exactly what’s happening, but it’s not as per the manual, and trying to build a curve has resulted in frustration every time. I was trying to build crossfader curves using this, or the control variant.
envdetect is broken. It can crash emote, the H9000 and the host.
