Home Forums Products Stompboxes Recommended expression pedals for H90 Reply To: Recommended expression pedals for H90
#172169
joecozzi
    Congrats on your new H90! Based on the documentation alone, Source’s dual expression pedal uses pots beyond the optimal range Eventide recommends, which is 10-25 Kohms. That does not mean the pedal will not work, it most likely will. But, you’ll experience a more linear range with the Mission.
