Home › Forums › Products › Stompboxes › H9 External Tap not working when heel down › Reply To: H9 External Tap not working when heel down
#172410
    Sorry for the issues you are having.
    In H9 Control, can you go to Pedal Settings > General Settings > Use Expression Pedal, Aux Switch, or Both and set this to Both?
    Are you using a Y-cable to connect both devices to the H9?
