Home › Forums › Products › Stompboxes › Setting up feed volume with exp at FRONT end of an algorithm block? › Reply To: Setting up feed volume with exp at FRONT end of an algorithm block?
#172415
John Czajkowski
    Thank you for the info—I can’t wait to dig into it!
    Not sure if this should become a separate post, but I’m simply astonished at the 3-dimensional image of the delay block in the Another Brick program. What on earth is going on there? I was working on new preset using this as a template and thought I was hearing/mis-sensing things at first after exercising in maybe  too much heat!
