Home Forums Products Stompboxes H90 Wet Dry Wet Help Reply To: H90 Wet Dry Wet Help
#172546
ptw2uk
    Setup =
    Guitar into guitar input of ES8
    Pre loop pedals- Tuner and Wah (not in looper)
    Loop 1- Fuzz
    Loop 2- Compressor
    Loop 3- Ep Booster
    Loop 4- POG
    Loop 5- Overdrive
    Loop 6- Distortion
    Loop 7- H90 (stereo output)
    Loop-8 (Not In Use)
    Volume Loop- Gigrig Humdinger (this is splitting the signal. Send from volume loop to Humdinger, Isolated out of humdinger to dry amp, buffered output of humdinger to volume return of es8) The volume loop is placed after loop 6 and before loop 7 in the chain so that the dry signal SHOULD only be going to the dry amp and the H90 SHOULD only be outputting the signal from itself and not the prior gain stages.
    Output 1 of the ES8 goes to left wet amp
    Output 2 goes to right wet amp
