Home Forums Products Stompboxes H90 Wet Dry Wet Help Reply To: H90 Wet Dry Wet Help
#172551
joecozzi
    How do I prevent the prior gain stages for getting to the wet amps so I can have just the wet signal going to them? I feel like this has not been explained yet. Sorry if I am missing something.
    There are two ways to accomplish this, there’s a global Kill Dry and then each Preset has a Kill Dry parameter. The most straightforward way is setting this globally. Go into the System Menu > Global > 2nd page – Set Kill Dry to ON. This way, every Program will not output a dry component to the signal, only the result of the wet effects. Keep in mind that it’s advised to run your effects in Parallel on the H90, mainly if you stack two wet effects together or three if you employ a stereo insert. If you use a serial chain, it will sound too muddy. Imagine a wet delay going into a wet reverb. Parallel routing will give you the best result.
