Home Forums Products Stompboxes H90 Wet Dry Wet Help Reply To: H90 Wet Dry Wet Help
#172553
joecozzi
    Press the Routing button on the H90. With the first quick knob you can go from serial routing to parallel routing. Keep in mind routing things in parallel requires you to have two presets going to the wet amp at all times. If you only want one for any given program you can use serial routing with the THRU utility as the second algorithm.
