Home › Forums › Products › Stompboxes › H90 – why am I getting mono out? › Reply To: H90 – why am I getting mono out?
July 27, 2023 at 1:17 am
#172716
This is super confusing. I have the H90 set up for dual routing as suggested in the manual (guitar into input 1, output 1 into pedal switcher, back into input 3 and out to amps via output 3 and 4). Then I get mono out from outputs 3 and 4.
if I change to insert mode and remove the pedal switcher I get stereo out from output 1 and 2. Maybe I should use insert mode and have the pedal switcher running as a mono insert via output 3/input 3 as suggested in the manual, but all my presets are created in dual mode. And why can’t I get stereo out using dual mode?
