Home Forums Products Stompboxes H90 Control Bank program order change Reply To: H90 Control Bank program order change
#173070
joecozzi
Is there a easy way to change the order of program in a playlist?
The easiest way to customize a playlist is using the H90 Control application, which allows us to copy, paste, and overwrite Programs to the correct positions. We can also create new lists and move between lists.
Also is there an easy way to transfer program from linear mode to Dual mode. I realized that I prefer the dual mode after made a playlist, and as the two mode doesn’t communicate,I had to save each program one by one on my computer and then copy the in dual mode.
There isn’t any easy way to transfer Playlists between Insert and Dual mode, but you used the best alternative.
