Home › Forums › Products › Stompboxes › H90: connecting multiple inputs (one stere plus one mono) › Reply To: H90: connecting multiple inputs (one stere plus one mono)
August 14, 2023 at 11:46 am
#173126
It sounds like you want to connect two instruments and process them both with the same effects. Connect the stereo one to inputs 1&2 and connect the mono input to Input 3. Position Insert 1 before the presets and make sure the Insert Mix is set to 50%. This mixes the signal from the stereo input and the mono input and you can route it to two Presets in either serial or parallel configurations.
