Home Forums Products Stompboxes Can’t save for the second time within a month Reply To: Can’t save for the second time within a month
#173184
cellicello
    Thank you for your reply.
    Sorry, save a Program.
    I can’t reproduce it, as I did a Recovery for the second time within 30 days because I had the same issue.
    I know about the 3-dot icon to “Save to Library”
    But usually, the name of the Program will stay after I change it.
    And the (*) will disappear when I press Save in the up-right corner.
    In my case, I could neither change the name nor Save (the * will remain)
    and my modification on preset will not be saved either.
    I used the power plug from Eventide from day one.
    I had another problem, before this one 3 days ago.
    No sound was coming out from the out 3 in Dual mode at a sound check.
    I was using this setting every day for a couple of days.
    It took me 40 minutes to check all the cables of my pedals
    to finally unplug the H90 and it worked again.
    How can I use with confidence this pedal for a job?
    I contacted the support team and told me that if it happened again,
    Tell the details.
    I do not wish that to happen again, I wanted to use this pedal,
    but I plan to sell it.
    As I mentioned before this pedal makes me spend too much time to let it work.
