Home Forums Products Stompboxes H90 CV control Reply To: H90 CV control
#173683
fiddlercrabseason
    Hi fiddlercrabseason, When using CV with H90 use the EXP 1 or EXP 2 settings in the I/O section of the system menu depending on which input you’re connecting to. Then, whatever parameters you assign to the expression pedal in the Parameters menu will be controlled by the control voltage.
    Tried that, but there’s no response on the H90  Is H() receiving CV on tip or ring of TRS?  (I’m sending on ring, so might need a splitter…?)
