Home › Forums › Products › Stompboxes › More H90 programs… › Reply To: More H90 programs…
August 29, 2023 at 6:03 am
#173709
You can also import entire H9 Preset Lists to the H90. Here are a few. The Parent Thread links were broken in the forum reshuffle, but the Direct Downloads still work:
https://www.eventideaudio.com/forums/topic/user-h9-preset-lists/#post-155176
There are some H90 Program Lists from several end users uploaded at PatchStorage as well. Potentially, up to 99 Programs each / 198 Presets (although none of them are that hefty yet).
The 1000+ linked here so far should keep you busy for a while. Many, many more here at this forum – screenshot versions – from the days prior to the Preset Sharing access. Only 10 parameters each – easy enough to dial in.
