Home Forums Products Stompboxes H90 and Disaster Area Micro.Clock External Tempo Reply To: H90 and Disaster Area Micro.Clock External Tempo
#174021
    Sorry, I’m not familiar with the Micro.Clock so this will take some troubleshooting and experimenting with different settings to work properly. You may need to contact Disaster Area to ask them how to set it up.
    Did you set the aux input on the H90 to be a switch and calibrate it with the Micro.Clock connected? https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/system-menu/io.html
    How did you map the tap tempo on the H90 to respond to the switch?
