Home › Forums › Products › Stompboxes › H90 and Disaster Area Micro.Clock External Tempo › Reply To: H90 and Disaster Area Micro.Clock External Tempo
September 5, 2023 at 12:40 pm
#174023
Yes I have the Sw 1-3 set with the micro clock connected. When calibrated I pressed the foot switch like tap tempo. The first dot would tap in time and then stop and go black. The tempo is in global mode. Do I need to map more on the H90? The micro clock is set with its TRS Tap out and N-O (normally open) function. This device has worked with my timeline, Hx stomp, and El Cap before.
