Home › Forums › Products › Stompboxes › H90 and Disaster Area Micro.Clock External Tempo › Reply To: H90 and Disaster Area Micro.Clock External Tempo
#174024
    Yes, you need to map the footswitch to the tap tempo parameter.
    You can do this per Program, or Globally.
    Use perform mode to map it per Program (Parameter: Tap Tempo, Ctl Source: Aux Switch) – https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/play-modes/perform.html#map-to-external-controllers
    Use Global – Pedal Control to map it globally (same parameter and Ctl source as above) – https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/system-menu/global.html
