Home Forums Products Stompboxes How to permanent change to dual routing in pre/post on H90? Reply To: How to permanent change to dual routing in pre/post on H90?
#174202
joecozzi
    Once the H90 is set to Dual Routing Mode it’s up to you to set the signal routing for each Program in your Playlist. The only way to ensure every Program has Preset A in path 1 and Preset B in path 2 is to do it manually. The easiest way to copy this configuration is using H90 Control and just copy it to every position.
