Home › Forums › Products › Stompboxes › External Midi Control and the Control App › Reply To: External Midi Control and the Control App
September 25, 2023 at 7:45 am
#174318
re your quickknob mapping: If your controller does not allow you to bias the button min/max on a preset basis, your exp pedal idea (or knob on the controller?) might be your only path(s) to victory.
re your hotswitch mapping: Changing your source controller’s button behavior from “latching/toggle” to “momentary” should do the trick. But here again, if you can’t adjust your controller’s button behaviors on a preset basis…
