Home › Forums › Products › Stompboxes › H90 – Mute Path 2 in Dual Routing? › Reply To: H90 – Mute Path 2 in Dual Routing?
October 11, 2023 at 7:29 am
#174620
If you’d like to have a program with only one active path, you can add a Mute algo to the other path.
If you want to have a program with 2 active paths and mute one of them on the fly without switching to another program, you can map a HotSwitch to the preset’s Out Gain and set it to minimum.
