Home Forums Products Stompboxes H90 Wah Pedal without artifacts? Reply To: H90 Wah Pedal without artifacts?
#175549
    Thanks for sharing this. It looks like you have MIDI CC #8 mapped to the “Bottom” parameter to create the Wah sweep, is that correct?
    Instead, you should your controller to Manual Mod, that is the intended parameter to be mapped for an expression pedal Wah control.
    Let me know if that improves things.
