Home Forums Products Stompboxes H 90 – freezing function Reply To: H 90 – freezing function
#175550
    Ok, for this you can route your presets in series and use HotSawz before Polyphony to add a synth sound before you freeze it. Then you can bypass HotSawz and your dry sound will be layered with the Freeze sound. If you have a fuzz pedal you can use that as an insert before Polyphony.
