Home Forums Products Stompboxes Using H90 Control with 2 H90 pedals Reply To: Using H90 Control with 2 H90 pedals
#175668
jm345
    I found the answer to my own question, but will post here in case anyone else finds this useful. Essentially, you can use the Mac terminal two open a second instance of the H90 Control app. Here are the Steps:
    1. Go ahead and open your first instance of H90 Control (and connect to one of your H90 pedals)
    2. Next, open the Terminal app (generally found in the Applications/Utilities/ folder).
    3. in Terminal, navigate to the Eventide folder in your Applications folder. For me, this is done with the following command: cd /Volumes/Macintosh\ HD/Applications/Eventide (depending on your file structure, this part may be different for you)
    4. Finally, typing the following command in Terminal will open a second instance of the H90 Control app: open -n H90\ Control.app
    Hope this info helps someone else. (Image attached)
    Thanks for this. Using Terminal I was able to open a second instance of H90 Control. I only have one H90 at the moment but I assume it will show two H90s and you just pick the one you want to connect? Is this method still working without issues? Thanks.
